Does Adobe Muse include features from Edge Reflow, Edge Inspect and Edge Code?
May 30, 2017
I was recommended to use these Edge programs, but it seems they are not being developed anymore.
Should I use the available versions for them or does Adobe Muse include everything Edge (Code, Inspect, Reflow) did?
218
Likes
Reply
Community Guidelines
1 Correct Answer
Adobe Community Professional , May 30, 2017
JosephLabrecque Adobe Community Professional , May 30, 2017
Not directly. Muse does do a type of responsive design and is a visual layout tool... so in that way is somewhat similar to Edge Animate/Edge Reflow... but only in the most basic way. It is much more different than similar. Nothing at all like Edge Code.What are you looking to do? Maybe that will help direct you to the correct set of software.
Likes
Jump to answer Jump to answer
May 30, 2017
Moved you question to the Muse forum as the Lounge is not for technical questions or answers. Hopefully this will find your answer quickly.
Likes
Reply
May 30, 2017
Thanks, Kat!
Likes
Reply
May 30, 2017
You are welcome. If you find that your answers are not here let us know and we'll try another avenue.
Likes
Reply
May 30, 2017
Likes
Reply
May 31, 2017
Well, I'll create websites for marketing purposes. So I need design tools that help me quickly build websites and save time.
I was also told to use webflow, macaw, pinegrow and coffeecup responsive
Likes
Reply
May 31, 2017
Muse should be fine for marketing sites as a design tool. Note there is no way to directly edit the code - Muse is purely a design tool for building small websites.
Likes
Reply
janisd97294262 AUTHOR LATEST
Jun 01, 2017
I see. Thanks a lot for your help.
Likes
Reply
