Locked
1
Edge Web Fonts disappeared from Design Mode in Muse
Community Beginner ,
Jan 18, 2021 Jan 18, 2021
I am hosting an Adobe Muse website. The main fonts is Source Sans Pro (an Edge Web Font). It’s no longer visible in de Design Mode. In the preview mode everything is fine.
I could replace all instances of the font with the Adobe Typekit alternative. But that is a lot of work.
Any advice on how to solve this is much appreciated.
All the best, Dimitri
253
Jan 20, 2021 Jan 20, 2021
As long as it works on the server, that's all that matters.
When things stop working in Muse, nobody is going to fix them for you.  Use Muse at your own risk.  I================
Important Announcement about Muse
https://community.adobe.com/t5/muse/important-announcement-support-for-adobe-muse-ends-today/td-p/11...
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Votes
Jan 27, 2021 Jan 27, 2021
Perdón pero este problema lo tengo yo ahora, y antes, jamás tuve ese problema con Adube Muse. Esto significa que Adobe está "destrozando" al mismo Muse para que dejemos de usarlo?? porque mi problema apareció después de haber instalado Adobe Creative Cloud!!!
Votes
Pudiste resolverlo Dimitrivan?? si supieras alguna novedad, me avisas por favor. Yo tengo el mismo problema, sólo que con ROBOTO y toda tu familia de tipografías
Votes
