I need some help whit my site.
If you se the pic below. I have a menu at the left where the red ring is. When i try to scroll the contents in the menu it won't scroll. What happens is that, the content in the page "Home"( Blue ring) is scrolling instead. What can i do to scroll the menu contents instead?
The content in the red box is on the master page and is made with compassion widget.
her is a link to the site in business catalysator
Hey cathrinen,
Looks like this is been an issue with a third party widget.
We don't have a lot of access to the functionalities of any third party widget.
Hence request you to reach your widget provider for further investigation on this.
Ankush
Hey cathrinen,
Ankush
This is another question to the same website. Not the original problem. I have made this site from scratch again.
No link available?
The link is worker here
What´s the question?
The link still is the old website?
Menus dont scroll. Why should they. They are fixed to their menu-item, aren`t they?
Ask the compassion widget vendor. Where did you get this widget from?
Where is the other question? The origin question is marked to be solved.
Even if it is not solved for you, we can`t have insights in widgets from 3rd party vendors.
Best Regards,
Uwe
