Hi Folks,
Just trying to optimise my workflow. I have a bunch of re-used common parts across a Muse website. I get the function of a library item - But my question relates to if I can make this even easier. I wanted to find out if there was a way to edit a library part so that it automatically updated where ever it appeared across the site - Much like a linked eps in an indesign document.
If not, I reckon it would make a pretty powerful feature
Yes, this is possible. The workflow:
Hi Gunter,
Thank you - This makes sense for static graphics. I was actually thinking for content parts - Ie: other muse library items with breakpoints included? Not possible I guess!
Concerning breakpoint: They are supported, if already existent. What that means, you may see here:
Changing „Muse created“ library elements together by editing the library element itself isnt implemented yet. But the „Content“ panel, which only works with text for now, is named „Content“ and not „synchronized text“.
This may (or may not) indicate future developments.
Thank you Günter,
I reckon that will become a very powerful part of muse - Like the indesign book, where it uses a bunch of indesign documents, each independently edited and updated! Looking forward to it
Cliff
