Highlighted
AUDIO Problem: Premiere CC Does Not Import Audio Track of a Video, and Does Not Import an Audio File
Explorer ,
Oct 29, 2016
Hi, everybody!
So I figured I have an audio problem.
That happened not only with a video file that has sound but also with an audio only file.
First of all, I tried importing my .mov video, which couldn't be done (file details below in picture 1 & 2). I had to install Quicktime player in order to be able to import the video. But no audio track comes with it, just video. I recently had to re-install my Windows 10, maybe I am missing some codecs?
But what's weird, is that I had a problem with a different (audio) file even before re-installing Windows and all Adobe programs (before re-install I had no problem with the before mentioned video+audio file). So the way it looks is that I import that audio file (file details in picture 3), try to play it, but that little pin doesn't move. I can't move it either.
Screenshot can be seen on picture 4, with the arrow pointing at the blue line that shouldn't be blue. Another fact: when the audio file is imported, it says it has 15fps and a resolution of 640X480. That doesn't make sense because it's audio only.
Things I already tried and did not work:
- importing both kind of files through Media Browser, but that doesn't do the trick
- installing and using ASIO codec
- reinstalling Premiere Pro CC latest version
- updating my audio drivers in Device Manager
- logging out and signing into Premiere
- restarting computer
- deleting media cache files
Just for the record, so far I am not having problems with other files, and they get imported fully and correctly.
Do you guys have any ideas on how to solve this?
IMAGE 1 & 2: The Video File
IMAGE 3: Audio only file
I got around this (which I had big problems with) if it is the same problem, after reading two tricks (which is stupid that I had to do it) in other posts.
1: You can download MPEG_StreamClip (Free) which you just run it through that and it fixes the audio so PrPro recognizes it. This worked most of the time. I then replaced the clip with the new output from Streamclip.
2: The other fix, more stupid but worked 100% of the time. Was to copy the same exact clip to a different folder. Then import or replace the original clip with the copy from another folder. I don't know why it works other than it recreates the WaveForm and\or Peak file. These are the annoyances that really upset me.
Good luck.
36.6K
Likes
Community Guidelines
Explorer ,
Oct 29, 2016
Hi, everybody!
Good luck.
36.6K
Likes
Contributor ,
Oct 29, 2016
Good luck.
Likes
Reply
Loading...
Oct 29, 2016
Another suggestion is to delete the preview & cache files, rename the folder the audio media is in, and re-start PrPro. Often just renaming the folder gets PrPro around the issue inside itself.
Likes
Reply
Loading...
Nov 30, 2016
I did the 2nd option and yes it found the audio file but I still hear nothing.
I then tried the 1st option but that didn't help with the sound.
Any other ideas?
Cheers
Likes
Reply
Loading...
Sep 24, 2018
You sir are true legend.
The 2nd method of this guy REALLY FIX my problem. If it worked it ain't stupid at all. Thank you very much sir.
Likes
Reply
Loading...
May 17, 2019
Thank you for your tips. They unfortunately didn't work for me.
I did finally work around the problem by extracting the audio and importing it separately. Thanks to the article Extract AC3 Dolby Digital with FFMpeg at Savvy Admin  I was able to use ffmpeg to losslessly extract the AC3 audio. After importing it separately into Premiere I linked it to the original video. The exact command in my case was
ffmpeg -i 0312-Dan-02.MTS -acodec copy 0312-Dan-02-audio.ac3
I installed ffmpeg using homebrew. This technique should work for most audio streams, not just ac3 streams. Of course, if you can't import audio at all like OP, then this probably won't help you.
Likes
Reply
Loading...
Sep 12, 2019
Option 2 worked for me. Thank you so much!!!!!!!!
Likes
Reply
Loading...
LEGEND ,
Oct 29, 2016
You should undo that.
Urgent Call to Action: Uninstall QuickTime for Windows Today -
Homeland Security warns Windows PC users to uninstall Quicktime | Fox News
Use this to remove it, making sure to engage the Powerful Scan to remove leftovers.
IObit Uninstaller, Best Uninstall Tool for Your PC - IObit
Likes
Reply
Loading...
Explorer ,
Oct 31, 2016
Thank you all for the help.
Jsantacroce :
1. I tried this solution, exported audio in mp3 and added it to the timeline. It was a few frames shorter than the video clip, but it did the trick. It's not the perfect solution, but it works. Awesome!
2. Unfortunately, it did not work.
R Neil Haugen:
I tried it, no success 😕
Jim_Simon:
That looks problematic, thanks for the heads up. What do you use instead of Quicktime then? As I mentioned, I couldn't import even only the video part  of my footage before I installed Quicktime.
PS: If you guys have any more ideas to make Premiere recognize audio, I would love to try them out and report the results.
Likes
Reply
Loading...
LEGEND ,
Oct 31, 2016
As a player?  My preference is for the following.
Global Potplayer
As a video format?  I just switched to the Blackmagic Pocket Cinema Camera, which shoots in RAW and ProRes.  Thankfully, both Premiere Pro and Resolve can handle the ProRes files without installing QuickTime.
Bottom line, if the software I use can't handle the QuickTime files without installing QuickTime, then I just will not use those files.  For me, NOT installing QuickTime is the priority.
Likes
Reply
Loading...
Community Beginner ,
Nov 04, 2016
This has been an ongoing problem for what seems like forever
have to question the "fit for purpose" of Premiere Pro as this is a "show stopper" problem
I started with only a problem from one of my cameras with .mov files, and it has since progressed to another camera with .avi files
I've been using the MPEG_StreamClip work around just to keep me going, but as others have said we shouldn't need to.
Adobe need to get their act together and sort it out once and for all
and before people start giving a list of things to do, I've tried them, countless times and still no joy
Likes
Reply
Loading...
May 08, 2018
Same problem here. I'm using Premiere 12.1.1 and no audio whatsoever with some footage. Have to import the footage in Final Cut Pro and then export audio and sync it....What is Adobe doing about this ?????
Likes
Reply
Loading...
May 08, 2018
On most rigs, this isn't an issue. Which doesn't mean it doesn't suck stinky stuff if it's happening on your rig. Sympathies ... seriously.
File the report on the new User Voice system they've got, a vastly improved setup from the old bug report setup.
Adobe Bug /Feature Request form: https://adobe-video.uservoice.com/forums/911233-premiere-pro
And btw, what's the media that sometimes out-puzzles PrPro?
Likes
Reply
Loading...
