Highlighted
editing one audio clip in audio track in Premiere Pro 2017 creates problems for entire track
Community Beginner ,
Jul 05, 2020
I have a question about audio editing in Premiere Pro cc 2017.  When I open the Audio Track Mixer and then on the slot fx1 I click on the dropdown and in the Noise Reduction/Restoration option, I select Adaptive Noise Reduction, it opens the Track Fx Editor Adaptive Noise Reduction dialog box or window.  I tweaked some of the parameters there, like the Spectral Decay Rate and Reduce Noise, I changed their values for one audio clip located in Audio Track 1 or channel 1 in my video, that’s A1.  But when I do that, everything in Audio Track 1 is affected, all the audio throughout the video, even though I made that change only to one audio clip that’s separate from the other audio clips in the soundtrack.  It messes up my entire soundtrack.
I struggle with this because I don’t want that change in Adaptive Noise Reduction to apply to the entire audio track, just to one piece or clip.  Is there a way to make that apply only to one clip without affecting the entire soundtrack on the same channel or Audio Track?  I appreciate the technical advice, thank you.
TOPICS
Audio
80
Likes
Community Guidelines
Jul 05, 2020
TOPICS
Audio
81
Likes
Jul 05, 2020 0
Jul 05, 2020
Use the Clip mixer to change just one clip. The Track mixer is of course to change the whole track.
Likes
Reply
Loading...
Jul 05, 2020 0
Jul 06, 2020
   Thanks for your advice, Neil.  And how do I get to the Clip mixer instead of the Track mixer?  I tried with a right click on the audio clip itself but it doesn't look like it has any clip mixer option to select.
Likes
Reply
Loading...
Jul 06, 2020 0
Jul 06, 2020
     I just found the clip mixer.  The problem is, there are no parameters to edit for an individual clip like you have in the Track mixer.  There is no spectral decay rate, fine noise reduction, any of those things.
Likes
Reply
Loading...
Jul 06, 2020 0
Jul 06, 2020
You have to apply effects to the clip in the sequence to edit individual clips for such things. I know some editors who have a regular group of audio effects they apply, and they saved the group as a preset with their typical 'starting' settings for their taste.
Then they drag/drop the preset to a timeline with everything selected. This gives them their clip setup they prefer, with the starting points they prefer, and they can then edit the settings for individual clips as they wish.
Likes
Reply
Loading...
Jul 06, 2020 0
Jul 07, 2020
   Thank you, but I still don't know the specific menu items or options to click on, in order to do this.
Do you create this in audio effects or where? By the way, I'm not talking about audio effects, as in special effects.  I'm talking about parameters like reducing noise and other things.  Do you know the specific options to select and click in order to create a preset for adjusting these parameters for a clip?
Likes
Reply
Loading...
Jul 07, 2020 0
Jul 07, 2020
Those are all effects ... located in the Effects panel.
Premiere is built around editing clips onto sequences in timeline panels, then adding effects to change the way things look and/or sound. All effects are found in the above-mentioned Effects panel. Some effects, like Lumetri, have their own panel which is a handy way of using them. But Lumetri can also be saved as a named  preset, which 'holds' the current settings, and drag/dropped onto clips from the Effects panel.
All effects after being applied to clips are controlled through their section in the Effects Control Panel.
And as mentioned, you can have several effects applied to a clip, each with specific settings you like, then select them together and save as a preset. When you apply that, all the involved effects will be applied to the selected clip/s with those settings as before. And of course, you can open and edit the settings of each effect still.
Likes
Reply
Loading...
Jul 07, 2020 0
Jul 07, 2020
Place the clip on another track than A1, let´s say A2 or A3 and keep it dedicated to that audio clip. Apply the Adaptive Noise Reduction and rock on from there. This is why the ability to have many audio tracks are there. 🙂
If i recall correctly you can have up to 99 audio tracks per timeline.
Likes
Reply
Loading...
Jul 07, 2020 1
Sep 10, 2020
Thank you Averdahl and thank you Neil.  I apologize for not replying sooner.  I eventually figured it out and I simply forgot about the question I asked here. 🙂
Thanks again!
Likes
Reply
Loading...
Sep 10, 2020 2
