Custom fonts wont work on homepage (index.htm)
Explorer ,
Mar 10, 2021 Mar 10, 2021
Hi guys, I'm using RH2020 2020.3.32.
I added custom font like in Peter's guide using the "@font-face" feature.
It works for me in topics, but in homepage they are not displaying correctly in PC's without this font installed locally.
This is how it shoud be (when font is applied correctly or when ran from pc with font installed)
This is how it looks on another pc (font enabled)
Interesting fact: if I disable font in web console, the font will be changed to a different.
This is how it looks in another pc (font disabled in web console)
This is how font is specified for a title
This is css:
TOPICS
New UI , Output presets
253
Explorer , Mar 12, 2021 Mar 12, 2021
Fixed with specifying @Font-face directly in custom css that in User Assets
Votes
Are you actually packaging the custom font with the output? I think that part is what is required to make the reference in the css work on machines that don't have the font installed.
Votes
Explorer ,
Custom font placed in same folder as css and present in final output in css folder
Votes
Explorer ,
Votes
See if Item 15 helps. Snippets (grainge.org)
________________________________________________________
See www.grainge.org for free Authoring and RoboHelp Information
Help others by clicking Correct Answer if the question is answered. Found the answer elsewhere? Share it here. "Upvote" is for useful posts.
Votes
Explorer ,
Mar 11, 2021 Mar 11, 2021
Hi Peter,
Unfortunatelly, nothing changed.
Here you can see, that font from User Assets css is applied, but do not work as expected.
Below you can see how it is added in robo and file:
font.css file:
Votes
  1. Create a new project leaving just First Topic in it.
  2. Add your CSS and skin.
  3. Set things up so that it should apply the font to your skin. Double check my instructions.
  4. Generate an output to prove it doesn't work.
See the Contact page on my site and send the project as instructed there. Do make sure you include a link to this thread and please do not email the project direct.
Votes
Explorer ,
Votes
Resources
RoboHelp Documentation
Download Adobe RoboHelp
