      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
How to copy web Pro robo help project in to production Robo Server without using robohelp tool publish option.
Aug 04, 2017 Aug 04, 2017
After generating WebHelp_Pro output for Robo help project, we don't have access to production Robo Server URL to publish the output using RoboHelp Office product option of Publish.
So in order to publish web help pro output to robo server , Is  copying the content of that folder to directly the server context location work ?
For Eg : if context name is robotest then we tried to copy in to the folder
robotest/server/general/projects/projectname
Then when we tried to access with url :
http://roboserverurl:8080/contextname/server?project=projectname
it is not working.
But if i publish the project using robo help office product publish option , it is working fine.
Please help how to deploy web pro robo help project in to robo server with out using publish option of the tool.
313
Advisor ,
Hi, JohnW and welcome to the Forums.
I am going to bring this to the attention of Adobe Engineering to see if anything has changed. Meanwhile, here is what I have understood about the proper publishing workflow.
The second method you described in your post (the method that works fine) is the supported and proper way to transfer (publish) your WebHelp Pro project to the RoboHelp Server. This is a bit more involved than simply copy/pasting output from
regular WebHelp to a server that does not have the RoboHelp Server database application.
There are a couple of reasons for this. In addition to feedback analytics, RoboHelp Server allows authors to limit access to authenticated authors and publish to "protected Areas" which are also authenticated. In order to authenticate and synchronize the information between the authoring client and the RoboHelp Server, it must be published using the required workflow using the Publishing Wizard as you described.
BTW. are you using Adobe RoboHelp Server 8, 9 or 10?
Thanks!
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
www.showmethedemo.com
John Daigle
Newport, Oregon
Votes
Aug 17, 2017 Aug 17, 2017
We are using RoboHelp server 10.
Please provide us the option or correct way of steps  to copy the web pro content to Robo Helpserver 10 without using publish option of RoboHelp studio to access the help page .
The url used to access help page was mentioned in the initial post , is it correct ?.
Please help us steps in detail to copy content in to server.
Thanks.
Votes
LEGEND ,
Hi there
As we wait for a more knowledgeable person to pop in, why are you opposed to using the Publishing option in RoboHelp?
Cheers... Rick
Votes
Resources
RoboHelp Documentation
Download Adobe RoboHelp
