iPad help output's index page is not showing a .jpg of our company's logo. I looked at output files in the... \!SSL!\Multiscreen_HTML5\ipad folder.
I see an index_rh.htm file there which doesn't have the .jpg. There is an index_rh1.htm file there that does. Can I safely delete the index_rh.htm file?
You only want to include all the output files in the event you want your output to work as intended.
While that sounds a bit snarky, there are many files created by RoboHelp that some will look at and question whether they should be included.
The bottom line is that while it may not appear to be the case, each of the files created does actually serve a purpose. And omitting any of them is an invitation for failure at some future point. So I'd simply include them all.
Cheers... Rick
Thanks, Rick. I know that the .jpg is located in the output folder, so I'm not sure if the index file that doesn't have the .jpg is being pointed to instead of the index file that does have the .jpg. I guess I'll have to experiment.
