Urgent help - Issue with Search results in Web help (Robohelp10)
Community Beginner ,
May 01, 2015 May 01, 2015
I am facing an issue with the Search tab of my Web help output. The search is performed only on a part of the text entered.
For example, I search for a word "Planning", the results are generated for "plan".
I search for the word "Table", the results are generated for "Tabl"
I search for "corresponding", the results for "correspon" are displayed.
Is this an existing issue? Is there any fix for this.
Please help.
378
Community Expert , May 05, 2015 May 05, 2015
Are you using the WebHelp Pro flavour? If so & you aren’t hosting your help on a server using RH Server, you’re wasting your time.
Votes
Have you applied all the updates & hotfixes for browser issues? Did you turn on “sub-string” searches in your WebHelp SSL recipe when you generated? Did this just start happening or has it always behaved this way? If you generate one of the sample projects, is it behaving the same way? If you change browsers, is it still happening?
Votes
Yes I have applied the updates.
This is the first online help I am creating using Robohelp10 and it is happening this way.
Facing the issue on all the browsers.
For your reference:
Votes
Contributor ,
Do you have the same issue if you first uncheck "Show results that include all search words" and then perform your search?
Votes
Can you show us a screenshot of your Search screen in the SSL recipe?
Votes
May 03, 2015 May 03, 2015
Search screen:
Votes
LEGEND ,
May 04, 2015 May 04, 2015
Hi there
This is the option Jeff was referring to. I see it in my own RoboHelp version 10. As we aren't seeing it in your screen capture, I'm wondering if this was an option that was added via a service release you haven't installed.
I do suppose another possibility would be that you are using RoboHelp for Word and perhaps that isn't an option with that application.
Cheers... Rick
Votes
I do not see that substring option here.
Votes
LEGEND ,
And you are using RoboHelp HTML? Or RoboHelp for Word?
If you click Help > About, what version is reported?
Votes
Using Robohelp for HTML.
Robohelp version 10.
Votes
Votes
LEGEND ,
Ahhh, good catch, Jeff!
Votes
Participant ,
One thing I'll suggest.
Did you try using quotes ( i.e., "planning" ) in the search field? Does that work, at least? If so, then a search savvy user will be able to recognize that "plan" is not what they want, and they'll immediately switch to using double-quotes.
Votes
Using double quotes works.
Thanks.
Votes
Resources
RoboHelp Documentation
Download Adobe RoboHelp
