This problem is only at the timeline.
A1 audio = only left ear.
A2 audio = only right ear.
A3 audio and below, no sound..
Seems like the problem came after the update.
Can someone figure this problem out?
never-displayed
Sounds like it's got 'dual mono' ... A1 is left, A2 is right.
If you made a screen grab of your timeline panel showing the control header block to the left, the little icons in the track headers will tell us what you're set to.
Votes
also, scree grab of your aidio preferences
Yeah, figured it out yesterday. Idk why they changed to this as standard for me ;/
So i just set all these to "0" and "standard"?
Thanks a lot for answers!
