Best Laptop for running Premiere Pro
  • November 17, 2017
  • 12 replies
  • 71620 views
Hey Guys,
I want to purchase a new laptop, looking for something value for money which is future proof (4K, 5K videos) for at least 4-5 years. I am currently using Premiere Pro and these are my options from the leading companies -
Apple -
Amazon.com: Apple 15" MacBook Pro, Retina, Touch Bar, 2.9GHz Intel Core i7 Quad Core, 16GB RAM, 512GB SSD, Space Gray, M…
Microsoft -
Amazon.com: Microsoft Surface Book 2 (Intel Core i7, 16GB RAM, 256GB) - 15": Computers & Accessories
Am also open to Lenovo, ASUS and HP. My brother would also be using this laptop for his development work occasionally, he is a full stack developer. Please help, this is all very confusing and I don't want to buy something that costs a bomb for no reason.
Thanks.
D
[Moderator note: moved to best forum]
If you're going to run Premiere Pro CC 2017 or 2018, forget about either of those two: These newer versions of Premiere Pro no longer support switchable graphics (or specifically, have the within-Premiere GPU selector disabled at executable level to the point where any attempt to modify the file to enable it will render the program completely unusable). And if those two laptops provide no provision at all whatsoever in the BIOS/EFI to disable the Intel graphics, the Premiere Pro renderer will become "permanently" locked to the integrated on-CPU Intel graphics, which may use either OpenCL or software-only MPE. And the integrated Intel graphics, especially in these laptops, will be excruciatingly sluggish even in OpenCL mode.
And Peru Bob is correct that it's impossible to "future-proof" any PC that long, in light of the fact that hardware and software companies do not like to support anything that's more than three years old.
Randall
Then what do you suggest I should buy?
Best,
Dhruv
Bill Gehrke
Bill
Thank you for your suggestion.
I fully understand the need to have the laptop plugged into an AC power source while editing.  FYI, recently working on friends Mac Book Pro (two generations old) while transcoding a 15 minute video the power plug actually got so hot that it was painful to the touch and the plastic started to become soft.  Have you experienced a similar issue with your Acer?  Also how heavy is your laptop?
Cheers
My 3+ year old laptop is an ASUS and weighs 9 pounds but it is a 17" screen for my old eyes but the brick never has felt the least bit uncomfortable.
Peru Bob
dhruvs85863305  wrote
Hey Guys,
looking for something... which is future proof ...for at least 4-5 years.
I don't think that's possible.
