johnj67038146
Jun 10, 2019 11:38 PM UTC
What sound card/USB are you using for Surround Sound?
Okay, I'm pretty stymied.  Haven't needed to do surround sound for over a year, now I need it.  The last couple of updates to Windows and to Premiere CC appear to have broken the SoundBlaster X-Fi which previously had worked fine for several years in a 5.1 setup.  Adobe no longer provides any recommendations other than ASIO.  Saw someone who said they were having luck with an Audigy FX, so got one of those, no dice at all.  So I got an USB device from StarTech, also no dice.  I cannot find any posts from anybody recently having good results with a specific sound card.  SOOOO -- are you doing 5.1 sound successfully on your Windows 10 machine with Premiere Pro CC 12.1.2 or 13.1.2?  If so, WHAT IS THE CARD?????????
Thanks!
johnj67038146
Jun 11, 2019 2:14 AM UTC
Just to add info -- I tried ASIO4ALL and it crashes Premiere CC 12.1.2 as soon as it is invoked.  Besides, it's a cheat, this really should work!
Jun 11, 2019 3:30 AM UTC
I'm working with Asio4all's process in 13.x without trouble.
johnj67038146
Jun 11, 2019 2:41 PM UTC
What sound card are you working with using ASIO4ALL?
