stephaniez7378630
Hi, I'm a designer and not a developer and I need major help with some custom calculation script.
I basically need a formula involving two fields, let's name them Field1 and Field2.
So if Field1 is less than or equal to 2000 then Field2=150.
However, if Field1>2000 then Field2=Field1 multiplied by .075.
Any ideas what the script would look like??
Thank you!!
try67
As the custom calculation script of Field2 enter this code:
var v1 = Number(this.getField("Field1").valueAsString);
if (v1<=200) event.value = 150;
else event.value = v1*0.075;
stephaniez7378630
thank you soo much this worked!!!!
