rindie
How do I make a box say Level 1 or level 2, 3, etc based on a numerical value in another text box? For example: If the number is 10-13, I need the box to say Level 1., How do I make a box say Level 1 or level 2, 3, etc based on a numerical value in
I am using Adobe Pro DC. Thanks in advance for your help!
Your title was cutoff because it was too long.
Can you post more details in the body of the reply or post and not the title?
Thank you
rindie
rindieAuthor
Thanks for helping out. I have about given up on it. I want to make a fillable pdf for one of the assessments I have to do. I linked to it here.  I want it to automatically say the appropriate level based on the composite score. Is there anyway to help make that happen?
Thanks for your help in advance.
Have you looked at other forms and the tutorials provided by Adobe?
Are the selections for CASII administration mutually exclusive?
I would make a selection for each category into a list box that allows only 1 selection or an exclusionary group of check boxes.
