Need help - PDF Forms that I created do not work in all browsers
  • February 27, 2016
  • 429 views
I have created many forms using Adobe Acrobat Pro that I have on our website and can be filled out and submitted (using a button via mailto:) directly to me.  Some people cannot fill in the forms, some people cannot sign the Digital Signature, and some people cannot submit.  The problems vary.  It seems like Internet Explorer works the best.  In any case, I am not sure what to do about this.  I really could use some help.
Thank you,
Lance
try67
Many browsers now have their own PDF viewer plugins (pretty much all of
them, except for IE, actually). And these plugins range from very poor to
mediocre when it comes to support for form fields, scripts, signatures, etc.
The solution is to either make sure that the Adobe plugin is used in your
browser (if available), or better yet, to download the file locally and
then open it in Adobe Acrobat or Reader directly. Unfortunately, you can't
enforce that on the users.
You need to ask them to do it and explain that otherwise they won't be able
to use the files correctly.
On Sat, Feb 27, 2016 at 3:13 PM, lancef107069 <forums_noreply@adobe.com>
Thanks try67.  That is what I have been doing so far.  I was hoping that there was another solution from within Adobe Acrobat Pro.  Thank you for the reply.  Very appreciated.
Lance
