Jun 14, 2018 1:01 AM UTC
What product do I need to load Load Acrobat activeX control for use from VBA
In an MS Access Database, using VBA calling the acrobat objects, I am creating and joining a number of different PDF pages, and creating a set of book marks in the resulting document.  In the development PC I have set a reference to the 'Acrobat' library.   All works fine on development PC, however I need to run the database on other PCs which do not have Adobe Acrobat installed.
Question:  Is there a way to simply install the Acrobat library on the other PCs, or do I need to install a full version of Adobe Acrobat on each machine.    If the latter what is the minimum (cheapest) Acrobat version I need to purchase to get the Acrobat reference installed.
Thanks
Bernd Alheit
Bernd AlheitCorrect answer
Jun 14, 2018 6:00 AM UTC
You need Adobe Acrobat Standard on each machine.
Bernd Alheit
Bernd AlheitCommunity ExpertCorrect answer
