Sep 25, 2025 2:11 PM UTC
Activating Fonts from Adobe Fonts that clash with same name system fonts
HI there
Has anyone out there come across the issue of attempting to activate the recently added Arial, TNR, and Symbol fonts from Adobe fonts where they fail to activate due to error 'font with same name already exists'?
Has anyone found a way around this without removing the same named system font verions (this is on a Mac OSX Sequoia).
Reason for asking is that by using the Adobe fonts versions my company is licensed for appropriate use in their products, not so if using the system versions.
Thanks 🙂
Tarun Saini
Tarun SainiCorrect answer
Sep 25, 2025 2:23 PM UTC
Hi @nrobson-font management,
Thanks for reaching out! We're sorry to hear about this. Please try the steps mentioned in the article based on the error message you are getting- https://adobe.ly/3KdFqw2
Let us know if that helps.
Tarun
Tarun Saini
Tarun SainiCommunity ManagerCorrect answer
Tarun
Oct 6, 2025 12:14 PM UTC
Thanks for the reply @Tarun Saini but im afraid that doesnt help as the fonts are system fonts - these cannot be deactivated by font book, or any other font app. The removal of system fonts is not advised by Apple.
I was hoping a user may have also come across this and found a work around.
Cheers
Noel
Font-manager-Nod
