Adding Variable Fonts to Web Project
  • February 22, 2023
  • 63 replies
  • 13568 views
I'm having issues adding a variable font to a web project.
It doesn't matter which weight I select, the only one I'm able to add is "extralight" (see screenshot).
I'm not sure if I'm doing something wrong or if this is a bug.
Can anyone help with this?
    Correct answer Aneta Ivanova
    Second option is copy pasting the import code into your CSS AFTER the Typekit CSS and fixing the issue yourself by adding the full range of weights.
    April 2025, still a problem. Can't make it work..
    christine_haynes
    I am having same issue with Deuterium Variable and can not use my webkit embed code for Klaviyo because it's only pulling the first isntance (Thin) and I need Medium. I was able to add CSS to my Shopify site to pull Medium instance but the font loads slowly and shows Thin first.
    I'm facing the same issue while using Wordpress+Elementor. Trying to import Marilde Display Variable.
    After digging into the code, I saw that TypeKit imports the font with a fixed font weight:
    @font-face {
    font-family:"marlide-display-variable";
    src:url("https://use.typekit.net/af/26a9a4/0000000000000000774ba8d7/30/l?primer=7cdcb44be4a7db8877ffa5c0007b8dd865b3bbc383831fe2ea177f62257a9191&fvd=n4&v=3") format("woff2"),url("https://use.typekit.net/af/26a9a4/0000000000000000774ba8d7/30/d?primer=7cdcb44be4a7db8877ffa5c0007b8dd865b3bbc383831fe2ea177f62257a9191&fvd=n4&v=3") format("woff"),url("https://use.typekit.net/af/26a9a4/0000000000000000774ba8d7/30/a?primer=7cdcb44be4a7db8877ffa5c0007b8dd865b3bbc383831fe2ea177f62257a9191&fvd=n4&v=3") format("opentype");
    font-display:auto;font-style:normal;font-weight:400;font-stretch:normal;
     Instead of importing it with the real range of the font like so:
    font-weight: 100 1000; ( or whatever it is for the specific font )
    So this weight indicated in the import file will be the only weight you will be able to use.
    The only workaround I've found is using this:
    font-variation-settings: "slnt" 0, "wdth" 100, "wght" 300; and choosing the right settings.
    Hope that helps someone, but @Adobe , this is ridiculous and looks like an easy thing to fix if you wanted to fix it.
    Aneta IvanovaCorrect answer
    Same problem here. okt 2024...
    Tarun Saini
    Hi
    @Marcus_Brown
    Thanks for reaching out . Could you please elaborate more on the issue you're facing? If possible, can you share the screenshot of the issue?
    Tarun
    No screenshot needed. Variable fonts doesn'd work in Webflow. Please solve this problem. Thanks
    jpweller
    I'm using Webflow, and on further research, I belive this is actually a Webflow issue. I got it working using custom code. You need to use the "font-variation-settings" property. For example:
    strong {
      font-variation-settings: "slnt" 0, "wdth" 100, "wght" 700;
    jpweller
    Same issue here, only replying so that maybe Adobe will do something about it
    For anyone looking to use a variable font with a tailwind project
    I was able to get the variable fonts working using the fllowing syntax:
    extend: {
        fontFamily: {
            'header': [
                '"magno-sans-variable", sans-serif',
                    fontVariationSettings: '"wght" 800'
    Same problem with Avada theme for Wordpress and the Sole Sans family...
    May 2024 still a problem with Adobe Variable fonts. This problem occur more then a year now, why can this be fixed?
    Adobe variable fonts are UNUSABLE in Webflow. Please fix this @Neelamk
    Same problem here. Trying to add additional instances of Postea Variable and all I can get is Regular (or Italic, which I don't need for this project). I am trying to use for website built with Format.com. Very frustrating, and live tech support from Adobe just sends me to articles that don't solve the problem. Can Adobe suggest a workaround? Perhaps a way to save an instance as as separately named font? From what I can tell, all you get is the standard weight/style under the family name. Or maybe the foundries could issue versions of the font with each instance named separately.
    Having same issue as others in Webflow, but with Objektiv Variable, only base font and no variable controls. Update?
