Aug 21, 2021 9:01 AM UTC
Is there a way to activate fonts for my registered products?
hello, I'm working with an old version of creative suite (15.1) that is installed on my desktop - it's registered on my adbove account and I have the creative cloud installed.
I'm trying to activate more fonts to use with it but it seems I have to subscribe to a plan to do this - but they all cover the apps that I already have.
Is there a way to activate fonts for my registered products? Any tips much appreciated
Thanks
Chrissi
Brad @ Roaring Mouse
Brad @ Roaring MouseCorrect answer
Aug 22, 2021 7:30 AM UTC
Your Creative Cloud subscription gives you access to the fonts, either through your Creative Cloud desktop app, or through the website at https://fonts.adobe.com/
You need to be signed in, of course, but once activated, they are available for use in any app, not just Adobe apps
Brad @ Roaring MouseCommunity ExpertCorrect answer
Doug A Roberts
Aug 21, 2021 9:04 AM UTC
No, I believe Adobe Fonts only works with CC versions.
edit: incorrect! See below.
