My AME is not taking up for rendering when triggered from After Effects. Please help. Using MacOs
Kartika Rawat
Hi there!
Sorry to hear that. Do you see any error codes or messages? Which version of both applications are you using?
Let us know.
Kartika
Dip92Author
Hi, Thanks for your reply..There is no error code. It is just that the AME remains blank without taking up the queue triggered from AE. This is a very common issue that is reccurant always and then suddenly goes away and then it came back again. Kindly help in resolving it as I am always using the latest enterprise versions for all Adobe Licenses and still facing this issue. Thanks!
