Font issues with Roboto and SF Pro Display
  • April 21, 2020
  • 3781 views
Hello, I have both Roboto font and SF Pro Display installed on my Mac.
when I use them in XD everything seems fine, there is no 'missing font' message or anything like that.
problem is the fonts look different than they are supposed to,
when other people on my team write the exact same sentence I write, it doesn't look the same, the letters look different, the spacing isn't the same etc...
I would love to get some help with that, thanks
Vishu_Aggarwal
Your teammates are working on mac or windows and where do they right the sentences? some screenshots would be helpful. And does the font size, leading, tracking and other font settings are the same as yours?
Vishu AggarwalAdobe Certified Instructor, Professional and Expert
Oriel94Author
Everything is exactly the same and we all have a Mac, i even deleted the fonts from my mac and they sent me the font file they have and the problem remaind
screen shot attached:
(red text is mine - SF Pro Display Font)
as you can see the spacing is way off even though theyre both set to 0
Oriel94Author
Hi there,
Sorry for the delay in response. I would like to follow up here if you are able to resolve the issue? If no, please try installing the SF Pro font on your machine and then check if it works fine.
Harshika
the problem still exists
i already tried re-installing the font and it did not help
i would really love to find a solution ASAP
