Jan 15, 2022 2:54 AM UTC
How to split circle into 10 equal parts in XD?
How to split circle into 5 equal parts in adobe XD?
I am new to this software.whether adobe xd support or not.
Thanks in advance.
<Title renamed by moderator>
Ares Hovhannesyan
Ares HovhannesyanCorrect answer
Jan 15, 2022 4:47 PM UTC
You have to use Boolean operations that combine several object. Here I use (draft model) rectangles to extrude common areas.
https://youtu.be/kEkzzjrqaM8
Combine objects using Boolean operations with shapes in Adobe XD.
Ares Hovhannesyan
Ares HovhannesyanCommunity ExpertCorrect answer
Feb 9, 2022 3:16 PM UTC
Thank you very much. I learned a new way.
AkinGn
Jan 15, 2022 4:37 PM UTC
Hi @PRASANNA22664589j33j this was a nice challenge I wanted to do it, hope this helps (sorry for the bad audio I should've plug my mic in lol) https://www.dropbox.com/s/zkeqdo33iu3jizo/slicing-circle.mp4?dl=0
Edit: Title of your post says "10 equal parts" but your post says "5 equal" so I did the 5 one but it gives you the idea I'm sure 🙂
Feb 9, 2022 3:15 PM UTC
Thank you very much. Finally, I did it in the same way.
