Dec 8, 2021 10:06 AM UTC
Problems with components with many states - lag and not requested drag
I am having an issue with components with many states performance
When I am editing the component state, and I click to open another state, it does not work properly, I need to click the right next state one by one until getting to the one I want.
Also on this, when I open a state, and I click an element to assign a behaviour or link, it takes some time to load the in formation, if I don´t wait for this time, it just "grabs" the element and locks to the mouse pointer, like if I was dragging and not dropping the element. It is very frequent situation.
    Atul_Saini
    Dec 9, 2021 5:25 PM UTC
    Hi Nara,
    Thank you for reaching out. I might need some more information here to assist you appropriately.
    • Are you not able to select required state from this panel?
    • Would you be able to share a short clip of the 2nd situation that you mentioned (Assign behaviour to states)
    Please share the OS build and the version of XD that you're using so that we may assist you appropriately.
    Atul_Saini
