Chris Kubiq
Nov 22, 2021 5:08 PM UTC
'Replace Fonts' Window disappears / Replacing Fonts not possible in XD 45.1
I urgently need to replace the missing fonts in a project in a large document.
When I click on a missing font and click on "Replace font", the window for replacing opens. As soon as I move the mouse pointer over the window, the window closes again and I cannot replace a font.
{Renamed By MOD}
Rishabh_Tiwari
Rishabh_TiwariCorrect answer
Jan 11, 2022 1:43 PM UTC
Hi there,
We're so sorry for the delay. Please update XD to the latest version which is 47 and let us know if you are still experiencing the issue.
Regards
Rishabh
studioavanti
Jan 11, 2022 1:37 PM UTC
Also, please don't pin a simple issue confirmation + vague excuses from Adobe as good answers, it's particularily disrespectful for users!
"We're so sorry to hear about the trouble…"? Not so sorry as users paying for a deffective software and awaiting for a fix that doesn't come for months now.
"You will definitely see improvements and fixes in the future releases of XD"
Why releases (plural), which release will fix this, when?
svnder
Oct 18, 2022 6:51 PM UTC
I hadn't seen this issue in a while but it has suddenly reappeared.. 😞
Harshika Verma
Oct 18, 2022 7:00 PM UTC
Hi @svnder,
We are sorry to hear you're having trouble replacing the font in XD. We will try our best to investigate the issue. A few more details will help us.
  • Would you mind telling us the version of XD installed on your machine?
  • Which operating system you're working on?
  • Does that happen with all files or with a specific file?
We will try our best to help.
Harshika
alperalin
Dec 21, 2021 9:10 AM UTC
It looks like I have a workaround. Maybe, it works for you too.
First, right-click on the missing font and select replace font from the menu. Do not move the mouse outside of the missing font. Otherwise, it will close the popup. When the popup opens, click on the missing font name with the mouse left-click. That will take focus from the popup and stop the popup's disappearing. After this, click the dropdown on the popup and select a font freely.
I hope this will help.
studioavanti
Dec 21, 2021 10:40 AM UTC
This tip is very tricky, it works 1 time on 10 for me
Dec 15, 2021 3:49 PM UTC
Same behavior here, for IOS, after the last update the problem is still here, I also tryied to replace a font by copying the new version and replacing the old one in the Fonts Folder but now I have same font twice with different naming 😞
Dec 15, 2021 3:52 PM UTC
and if it replaces, only in normal text but if the for example, I have an iconfont, is part of a component, the  font  inside components is not being replaced
Harshika Verma
Dec 17, 2021 7:30 PM UTC
Hi All,
We understand your frustration. The team is working on this issue and was able to find the root cause of the issue. You will definitely see improvements and fixes in the future releases of XD.
We are sorry for the inconvenience.
Harshika
Hydrant Dev
Dec 13, 2021 7:18 AM UTC
Also happening for me - pretty much useless file as I'm not replacing 100+ occurances manually...
MacOS Monterey 12.0.1 with M1 Max
Dec 2, 2021 7:54 PM UTC
Having the same issue here as well! The box disapears and cannot replace fonts using this feature.
Torugo Prando
Dec 2, 2021 6:15 PM UTC
I'm having some problems in the UI when I try to replace missing fonts.
  • Right click in the missing font > Replace font
  • A box appears in the right
  • When I move my cursor over the box, it desappears!
So, I cannot interact with the UI to replace my fonts
Rishabh_Tiwari
Dec 2, 2021 6:57 PM UTC
Hi there,
We're so sorry to hear about the trouble. I can reproduce this on my end and I have logged a bug. Please stay tuned to this  discussion for updates.
Regards
Rishabh
Dec 1, 2021 1:21 PM UTC
This option disappears as you move the mouse.
Example video below:
Can anyone help?
Rishabh_Tiwari
Dec 1, 2021 1:56 PM UTC
Hi there,
We're so sorry to hear about the trouble. Could you confirm if this is happening on a specific file or multiple files? If it's happening on multiple files, please share the version of XD and OS so that we can test this on our end and we'll escalate this further.
Regards
Rishabh
Dec 1, 2021 2:21 PM UTC
I can confirm this happens on every file I am currently using.
XD version: 45.1.62.3 x64
OS: macOS Big Sur, Version 11.6
Chris Kubiq
Nov 30, 2021 7:47 AM UTC
As a workaround sometimes helps:
Right click on the font to be replaced (missing font) while holding down the mouse button(!!),
release mouse button on the text (so only 1 click in total).
In one out of 12 attempts, the window then opens above the sidebar instead of next to it, then it can be used normally. So if it looks like this:
Still very annoying problem.
Rishabh_Tiwari
Hi there,
Regards
Rishabh
Nov 29, 2021 9:13 PM UTC
Still having the problem!!!
Rishabh_Tiwari
Nov 22, 2021 7:21 PM UTC
Hi there,
We're so sorry to hear about the trouble. Please share a few more details like:
  1. The version of XD and OS.
  2. Is this happening with a specific file or multiple files?
  3. Is this happening with a specific font? If yes, please share font details.
  4. Please quit XD and reboot the machine and check if that resolves the issue.
Regards
Rishabh
Nov 22, 2021 7:39 PM UTC
1. Adobe XD version 45.1.62.3 / OS macOS Big Sur 11.3.1
2. It is happening in multiple files
3. All fonts ( I tested)
4. I already did this, also used the Adobe cleaner to delete my XD.
