Aug 12, 2011 10:06 AM UTC
Embedded font using flash.text.engine works on AIR2.6 but no AIR2.5
I use the following embed statement:
[Embed(source = "C:\\Windows\\fonts\\Kids_Plain.ttf", fontFamily = "Kids", embedAsCFF="true")]
private var Kids:Class;
I use flash.text.engine class functions and the program runs fine on AIR2.6 on Android, but the text does not show on AIR2.5.  According to the Adobe documentation, the flash.text.engine class should work on the AIR2.5 platform.  Or is there something wrong with the way I embed the font?
Anyone know what the problem is?
Thanks in advance!
aimaobAuthor
Aug 12, 2011 11:50 AM UTC
I also tried Text -> Font Embedding on CS5.5 to embed the font, but the font still is not showing up properly on Android.
I am running out of ideas!
aimaobAuthor
Aug 12, 2011 2:21 PM UTC
OK.  I found out what the problem is. It is something else not relating to the embedded format & text engine that cause the problem.  The [Embed ....] format works.
