Jan 18, 2014 1:43 AM UTC
How to communicate between AIR desktop and AIR mobile applications using same WIFI network?
I am creating a desktop AIR application and a mobile "helper" application running on iPad.
I would like to be able to send messages from the desktop app to the iPad app and vice versa. I have looked at different options but can't seem to get this to work.
Using AIR 3.8 I have tried:
- ServerSocket / socket => Able to setup the server socket on my desktop but the iPad can not connect to it (IO_ERROR)
- P2P: Using netconnection rtmfp but though both desktop and ipad successfully connect the members count for the netGroup is always 1 and I get no neighbour connected event.
How should I do this? Is it even possible?
If I click a button on my desktop app I would like the iPad app to respond by showing a URL which is passed.
Just spend hours on this without any luck. How to connect via the Wifi network without knowing any IP addresses?
Here is my desktop code:
private var server:ServerSocket;
                              private var connectedClients:Vector.<Socket> = new Vector.<Socket>;
                              private function createServer():void{
                                        server = new ServerSocket();
                                        server.addEventListener(ServerSocketConnectEvent.CONNECT, onConnect);
                                        server.bind(7934); // this is the number of the port where your socket communicate
                                        server.listen();
                              private function onConnect(e:ServerSocketConnectEvent):void{
  trace("connected");
                                        connectedClients.push(e.socket);
                                        trace(e.socket.connected);
                                        trace(e.socket.localAddress + " / " + e.socket.remoteAddress);
                              protected function application_initializeHandler(event:FlexEvent):void
                                        createServer();
And the iPad code:
private var socket:Socket;
  // on the client socket application you have to create the connection and then manage (send and receive) data from the server
                              private function createSocketConnection():void{
                                        socket = new Socket()
                                        socket.addEventListener(Event.CONNECT, connectedToServer);
                                        socket.addEventListener(ProgressEvent.SOCKET_DATA, receiveData);
                                        socket.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                                        socket.addEventListener(Event.CLOSE, closeSocket);
  //pass to connect method the server IP and the port to comunicate
                                        socket.connect("0.0.0.0", 7934);
                              protected function receiveData(event:ProgressEvent):void {
  // here you can read all the packets sent from the server
  trace("receiving data");
                              protected function ioErrorHandler(event:IOErrorEvent):void {
  trace("ioErrorHandler: " + event);
                              private function connectedToServer(e:Event):void{
  //yes! you are connected to the socket server
  trace("connected to server");
                              private function closeSocket(e:Event):void{
  //your socket connection is closed
  trace("connection is closed");
                                        createSocketConnection();
If I start the desktop app nothing traces. If I then start the iPad app I get:
ioErrorHandler: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2031: Socket Error. URL: 0.0.0.0" errorID=2031]
Jan 18, 2014 1:59 AM UTC
Also to note:
When I start the desktop app and in the browser I go to http://127.0.0.1:7934/ it traces
true
127.0.0.1 / 127.0.0.1
so that part is working. How come iPad can't connect?
Jan 18, 2014 2:00 AM UTC
Changing the 0.0.0.0 to 127.0.0.1 doesn't work either =>
ioErrorHandler: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2031: Socket Error. URL: 127.0.0.1" errorID=2031]
I'm running in debug mode (fast packaging)
User Unknow
Jan 18, 2014 5:15 PM UTC
dont enter 127.0.0.1 anywhere. Its loopback url. Use 0.0.0.0 instead.
Also be sure that your firewall on desktop is disabled for fast testing purpose.
In my case I spent few hours and was like crazy monkey. Than typed ipad local ip to desktop firewall with selected port and this worsk.
I can use tcp or udp without any issues
