jadestarh65085165
The problem of Microphone.getEnhancedMicrophone() in AIR SDK 23
  • October 6, 2016
  • 17 replies
  • 3425 views
I am developing an android and iOS chatting app using air SDK 23.0 in flash builder 4.7.
The chatting server is Red5 0.6.
The mobile source code is following.
var devMic:Microphone = Microphone.getEnhancedMicrophone();
devMic.setUseEchoSuppression(true);
devMic.setLoopBack(false);
devMic.gain = 80;
devMic.rate = 11;
devMic.codec = SoundCodec.NELLYMOSER;
devMic.addEventListener(StatusEvent.STATUS, onMicStatus);
outStream = new NetStream(this);
if (useMic)
    outStream.attachAudio(devMic); // the phone speaker volume is lower and is impossible to hear.
outStream.publish(chatInfo.user_id, "live");
I use Microphone.getEnhancedMicrophone() function,
In this case, the microphone volume of my android is normal and the other side hears normally.
But the phone's speaker sound is so low I can not hear each other's words.
The above problem does not occur with the iPhone.
Before AIR SDK 23 released, I used Microphone.getMicrophone() with AIR SDK 22.0, The above problem does not occur with the android but has the echo problem.
What is the cause of this problem?
Please help me...
As an update, still not able to get this working on Android, and I have now tested on Android v6 on Intel (x86) chip and when I use getMicrophone() (no echo suppress) mic works fine, but if I use getEnhancedMicrophone() no mic access (ie. mic doesn't work at all).
Any help appreciated, thanks.
morgenshtern
The issue is still exists in AIR 30.0.0.107 sdk
Workaround with:
SoundMixer.audioPlaybackMode = AudioPlaybackMode.VOICE;
SoundMixer.useSpeakerphoneForVoice = true;
didn't work - big speaker turns on for a second - then sounds switches to back to voice speaker.
We have to use general microphone, without AEC. It's extremely inconvenient for our users, they have to chat with headphones.
Please fix it!
Has anyone been able to get echo suppression working on Android? If so, which air sdk version, which mic settings and soundmixer settings?
Can anyone confirm that on Android, using AIR sdk 23/swf 34 or Air 24/swf 35 and the following settings/code, that echo suppression works?
"MODIFY_AUDIO_SETTINGS" in manifest
function getmic():void
mic = Microphone.getEnhancedMicrophone();
mic.gain = 80;
mic.rate = 22;
mic.codec = SoundCodec.SPEEX;
function starttalk():void
     getmic();
Still trying to get this to work - thanks.
Can anyone confirm that on Android, using AIR sdk 23/swf 34 and the following settings/code, that echo suppression works?
mic.gain = 80;
mic.rate = 22;
HTC Android v4.1
Galaxy Note Android v5
Galaxy s7 Android v6
Can you let me know the settings you are using on Android to get the echo suppression to work?
Thanks.
Further to my post above, I have confirmed the generated swf version is 34, and I have tried to change the mic.gain to 50,60,70,80 and still get echo on the Android devices.
I have been able to get this working on iOS on devices iPhone 5 and higher (it does not work on iPhone 4s in our testing - voce is garbled with long, long delay) with slightly different values (which I also tried on the Androids and didn't work).
iOS settings:
    mic.noiseSuppressionLevel = -30;
    mic.codec = "speex";
    mic.encodeQuality = 5;
    mic.framesPerPacket = 1;
    mic.setUseEchoSuppression(true);
    mic.rate = 22;
    mic.gain = 60;
    mic.setSilenceLevel(0,200);
deesharm
Adobe Employee
Adobe Employee
January 24, 2017
Hi Spider22,
Could you please list out the Android devices that you are using for testing your application?
The performance of this feature will be varying depending upon the OS version and the device type.
Adobe AIR Team
Hi, I am not sure if this issue was resolved, but I am experiencing the same issue:
Android 4/5/6, Air 23 SDK
mic.gain = 80;
mic.rate = 22;
And I still get echo.
Thanks.
jadestarh65085165
The running environment of this project is not simple.
So I am preparing the environment of testing for you.
Thanks.
deesharm
Adobe Employee
Adobe Employee
October 21, 2016
Hi Jadestar,
We have investigated it further and found that if we use SoundMixer.useSpeakerphoneForVoice = true; in our actionscript code the application seems to be working fine.
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/media/SoundMixer.html
Kindly test it at your end and let us know about the results.
Adobe AIR Team
jadestarh65085165
I shared source code in dropbox
The link is following as:
Dropbox - PrisonerChat-test.rar
deesharm
Adobe Employee
Adobe Employee
October 7, 2016
Hi Jadestar,
Could you please help me by giving some guidelines to use the project that you shared.
I have successfully imported the project in Flash Builder. But when I started debugging, I got stream error with the URL mentioned in config.as. I changed the URL with my local server address but I got no success so far.
Could you please provide us some steps that is required to use the project for establishing a successful connection between iOS and Android device.
Adobe AIR Team
jadestarh65085165
Thank you for your answer.
I  have already set  MODIFY_AUDIO_SETTINGS in my app.xml.
This is as follow:
<uses-permission android:name="android.permission.MODIFY_AUDIO_SETTINGS"/>
and I have already set as you send the method. But the problem is equal.
How do I share my project for you? Please give me a way to share.
Thanks.
deesharm
Adobe Employee
Adobe Employee
October 6, 2016
Hi Jadestar,
Please share it through Dropbox.
We will investigate it further.
Adobe AIR Team
