Beantwortet
AS3 code help with drag and drop quiz
  • July 27, 2009
  • 1 Antwort
  • 3111 Ansichten
I have a flash drag and drop quiz that i would like to add different images to correspond to the correct veribage when the users have dropped the folder.
I have the text working ok when the user drops the folder (i.e. "yes, that is correct!", I'm sorry, that's not correct.", "Congrats, you're finished!")
I don't know where to start and I was wondering if it was possible to add an image from the library to the stage when the corresponding text is displayed on the stage?
I have the AS3 code below that I'm using.
Thanks for help in advance!
var startX:Number;
var startY:Number;
var counter:Number = 0;
folder_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickUp);
folder_mc.addEventListener(MouseEvent.MOUSE_UP, dropIt);
folder2_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickUp);
folder2_mc.addEventListener(MouseEvent.MOUSE_UP, dropIt);
folder3_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickUp);
folder3_mc.addEventListener(MouseEvent.MOUSE_UP, dropIt);
function pickUp(event:MouseEvent):void {
            event.target.startDrag(true);
            reply_txt.text = "";
            reply_txt2.text = "";
            event.target.parent.addChild(event.target);
            startX = event.target.x;
            startY = event.target.y;
function dropIt(event:MouseEvent):void {
            event.target.stopDrag();
            var myTargetName:String = "target" + event.target.name;
            var myTarget:DisplayObject = getChildByName(myTargetName);
            if (event.target.dropTarget != null && event.target.dropTarget.parent == myTarget){
                        reply_txt.text = "Yes, that's correct!";
                        reply_txt2.text = "Donec sed fermentum lorem. Suspendisse potenti. Pellentesque hendrerit tempor nunc, vitae semper risus gravida vel. Nam eu lorem sed nulla lacinia commodo vitae vel ante. Cras ac nibh dolor.";
                        event.target.removeEventListener(MouseEvent.MOUSE_DOWN, pickUp);
                        event.target.removeEventListener(MouseEvent.MOUSE_UP, dropIt);
                        event.target.buttonMode = false;
                        event.target.x = myTarget.x;
                        event.target.y = myTarget.y;
                        counter++;
            } else {
                        reply_txt.text = "I'm sorry, that's not correct.";
                        reply_txt2.text = "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Fusce a massa tellus, ut euismod urna. Phasellus bibendum pretium porta. Praesent sed elit vel odio ultrices dignissim in in tortor."
                        reply_txt3.text = "Try Again";
                        event.target.x = startX;
                        event.target.y = startY;
            if(counter == 3
        reply_txt.text = "Congrats, you're finished!";
folder_mc.buttonMode = true;
folder2_mc.buttonMode = true;
folder3_mc.buttonMode = true;
Dieses Thema wurde für Antworten geschlossen.
Beste Antwort von kglad
yes, to add a library object to the stage using actionscript assign the object a class, say ImageClass.  you can then use the new constructor to create an instance and then add it to the display list:
var image:ImageClass=new ImageClass();
addChild(image);
1 Antwort
kglad
kgladCommunity ExpertAntwort
addChild(image);
lleverAutor
Thanks a lot for the help!
Another question... how do i get the image to remove when a different image needs to be displayed
Example: The user drags the wrong folder to the circle... the sad face image appears, but when they drag the correct folder to the cirlce, they sad face disappear then the happy face appears.
Thanks again!
lleverAutor
assign its x,y properties:
image.x=22;
image.y=44;
Thank you so much!
