eslmaxx
Jul 5, 2021 3:25 AM UTC
Audio does not play in movieclip on first click. It plays on second click.
Hi Everybody,
I was editing an animate file I made in 2018.  When I exported it, I found that audio does not play when I click a button, although the animation does play.  When I click it the second time, the audio plays.
I have 6 movieclips on the stage and it is the same with each of them.  When I export the movie and click on any of them, the animation will play but not the sound.  When I click on any of them after that, or I click on the first one a second time, the sound plays.
When I just play the 2018 html file I can click on any of the movie clips and the sound plays with the animation.
The code in each movieclip is
this.ed4.addEventListener("click", fl_ClickToGoToAndPlayFromFrame_31.bind(this));
function fl_ClickToGoToAndPlayFromFrame_31()
this.gotoAndPlay(1);
exportRoot.stopped_.gotoAndStop(0);
exportRoot.missed_.gotoAndStop(0);
exportRoot.walked_.gotoAndStop(0);
exportRoot.wished_.gotoAndStop(0);
exportRoot.punched_.gotoAndStop(0);
I have the audio on the 3rd frame of the movie clip.
Does anyone have any idea what might be happening here?
Thank you in advance!
    kglad
    Jul 5, 2021 1:00 PM UTC
    users must interact with your site before sound can plan. (learn how to use your browser's developer console for debugging.)
    eslmaxx
    eslmaxxAuthor
    Jul 6, 2021 4:24 AM UTC
    It seems like they have to interact twice, though.  And this is a problem that occurs only when I export files, even if I don't edit them at all.  When I run the old file - an exact copy that was exported 2 years ago, the audio plays with the animation on a single click.  So I thought it must be something to do with updates in Animate in the past two years.
    Ok, I'll look into Chrome's developer console for debugging, assuming it is a bug and not what would actually be expected given the most recent version of Animate.
