Feb 19, 2024 6:59 AM UTC
Audio Quality drop ( grainy sound ) in player and exsport
Im making an animated video but when I import the audio it becomes realy grainy and low quality but sounds fine in the source file. It retains this quality drop in the exsport. Im using a wav file
n. tilcheff
Feb 19, 2024 8:21 AM UTC
Make sure that your source is a 44 100 Hz 16-bit PCM WAV.
If it isn't, convert it to the said format and reimport/update in Animate.
Nick - Character Designer and Animator, Flash user since 1998 | Member of the Flanimate Power Tools team - extensions for character animation
