markerline
Flash Pro CS6 and Adobe AIR (and Android APK)
  • July 11, 2013
  • 4902 views
I have a compiled SWF that I can't convert to a newer ActionScript 3.0 format.  Anything that I try breaks the file.  It is basically just an animation with a tad bit of code on the Movie Clips.  I can't seem to identify the culprit that causes the newer files to generate with errors so I have decided to use the load method to load the ActionScript 1/2 format into an AS 3.0 container.  This still does not work for generating APK's directly.
However when I generate a desktop AIR file it plays just fine.
Is there a way to take the AIR file and convert it to an APK using the command line?  I have heard of using adt on the command line but most posts speak of converting SWF's directly.  I would like to try it with the already-compiled AIR file.  If I use the SWF I might as well compile that into a non-functioning APK directly from Flash.  That's not what I'm looking to do.
Any help is greatly appreciated.
Correct answer kglad
you shouldn't "import" a swf.  you should load it.
you may still have problems loading it but, you're sure to have problems if you import it.  (ie, no actionscript will execute in the imported swf.)
kglad
if there's not much to the as2 swf, you're better off working with it directly to convert it to an as3 swf because there are a number of problems that can be caused by loading an as2 file.
do you have the fla that created the as2 swf?
markerline
Hi kglad,
Yes I have the original FLA.
I think you're right, working with it to convert it to AS3 would be optimal.  Unfortunately it is not such an easy task because I tried that route already and I thought I had a good file but in the Android APK it still played back strangely.  With the desktop AIR I didn't have any problems after using the original FLA to reauthor the SWF movie.
I also find it strange that when I try to import the SWF into a version of Flash below CC it does not import properly.  I guess at runtime it takes some of the ActionScript commands into account but at import-time to get it into the Library or on Stage it throws the AS out the window.
Best,
markerline
kglad
kgladCommunity ExpertCorrect answer
