Feb 2, 2025 10:30 PM UTC
Is there a way to fix my issue with sound is Flash 8
I'm really annoyed about how Flash 8 specifically uses sound on the timeline. I don't remember how sound works on the newest version of Adobe animate since I haven't used it in a while but in Flash 8 if you play a sound then it will play until it's done even if you pause the animation. Is there any way to change this so sound stops when you pause the animation?
    kglad
    kgladCorrect answer
    Feb 2, 2025 11:01 PM UTC
    assign the sync property to stream, not event.
    kglad
    kgladCommunity ExpertCorrect answer
    Feb 3, 2025 2:19 AM UTC
    Thank you
    kglad
    Feb 3, 2025 2:33 AM UTC
    you're welcome
