Sep 22, 2021 3:50 AM UTC
Low-quality audio; sounds slightly bit-crushed (i've looked everywhere for a solution)
HI! I'm currently using the newest version of Animate on Windows 10, and I've been having issues importing a .wav file to animate with. I don't know if I'm putting it in the right place (I'm putting it on a layer and just making a ton of new frames), or if something is off. Whenever I try to listen to the audio, while animating or after exporting, it sounds bit-crushed and low-quality. When I just listen to the file itself, it sounds perfectly okay. I edited the audio in Premiere, and the output is 48,000 Hz, at 16 bit. I messed around with the properties in the file in the library in Animate, but no matter what I tried (speech, MP3, raw, etc), they all still didn't sound pure. I REALLY want to start making this cool video idea I have, but the crappy audio is holding me back. Any thoughts? (thank you so much!!)
Jul 10, 2023 4:05 AM UTC
Was there ever a solution to this?
Mario_CR
Sep 25, 2021 7:44 PM UTC
Make sure the sound is 44100 hz not 48000. Go to the properties panel (Doc tab) >Publish Settings > More Settings and change the audio quality there instead, make sure you tick "override sound settings". That's the quality that will be used on export.
thebenhamAuthor
Oct 6, 2021 3:52 AM UTC
Thanks for the help, but it didn't seem to work. I tried exporting it too, but the audio quality no matter what setting, still sounds poor. Any other suggestions? Or specific things I could try within the "more setting" tab?
Mario_CR
Oct 6, 2021 5:30 PM UTC
Did you change the quality settings in the publish settings? I just tried it and it works fine.
