problem with loop Sound and a class
Good Morning. I'm working with a class made by a professional actionscript sound specialist (Andre Michelle).
The class loads a sound, changes its pitch, and plays it.
I want it to loop. I have added the (0, int.MAX_VALUE) in the play method but it only plays once.
Thank you very much for the help.
package {
	import flash.display.MovieClip;
	import flash.events.Event;
    import flash.events.SampleDataEvent;
    import flash.media.Sound;
	import flash.media.SoundChannel;
    import flash.net.URLRequest;
    import flash.utils.ByteArray;
	import flash.events.MouseEvent;
	public class Bucle extends Sound
        private const BLOCK_SIZE: int = 3072;
        private var _mp3: Sound;
        private var _sound: Sound;
		private var _myChannel :SoundChannel;
        private var _target: ByteArray;
        private var _position: Number;
        private var _rate: Number;
        public function Bucle( url: String )
            _target = new ByteArray();
            _mp3 = new Sound();
            _mp3.addEventListener( Event.COMPLETE, complete );
            _mp3.load( new URLRequest( url ) );
            _position = 0.0;
            _rate = 1.0;
			_myChannel = new SoundChannel ();
            _sound = new Sound();
            _sound.addEventListener( SampleDataEvent.SAMPLE_DATA, sampleData );
        public function get rate(): Number
            return _rate;
        public function set rate( value: Number 😞 void
            if( value < 0.0 )
                value = 0;
            _rate = value;
        private function complete( event: Event 😞 void
			_myChannel = _sound.play (0, int.MAX_VALUE);
        private function sampleData( event: SampleDataEvent 😞 void
            //-- REUSE INSTEAD OF RECREATION
            _target.position = 0;
            //-- SHORTCUT
            var data: ByteArray = event.data;
            var scaledBlockSize: Number = BLOCK_SIZE * _rate;
            var positionInt: int = _position;
            var alpha: Number = _position - positionInt;
            var positionTargetNum: Number = alpha;
            var positionTargetInt: int = -1;
            //-- COMPUTE NUMBER OF SAMPLES NEED TO PROCESS BLOCK (+2 FOR INTERPOLATION)
            var need: int = Math.ceil( scaledBlockSize ) + 2;
            //-- EXTRACT SAMPLES
            var read: int = _mp3.extract( _target, need, positionInt );
            var n: int = read == need ? BLOCK_SIZE : read / _rate;
            var l0: Number;
            var r0: Number;
            var l1: Number;
            var r1: Number;
            for( var i: int = 0 ; i < n ; ++i )
                //-- AVOID READING EQUAL SAMPLES, IF RATE < 1.0
                if( int( positionTargetNum ) != positionTargetInt )
                    positionTargetInt = positionTargetNum;
                    //-- SET TARGET READ POSITION
                    _target.position = positionTargetInt << 3;
                    //-- READ TWO STEREO SAMPLES FOR LINEAR INTERPOLATION
                    l0 = _target.readFloat();
                    r0 = _target.readFloat();
                    l1 = _target.readFloat();
                    r1 = _target.readFloat();
                //-- WRITE INTERPOLATED AMPLITUDES INTO STREAM
                data.writeFloat( l0 + alpha * ( l1 - l0 ) );
                data.writeFloat( r0 + alpha * ( r1 - r0 ) );
                //-- INCREASE TARGET POSITION
                positionTargetNum += _rate;
                //-- INCREASE FRACTION AND CLAMP BETWEEN 0 AND 1
                alpha += _rate;
                while( alpha >= 1.0 ) --alpha;
            //-- FILL REST OF STREAM WITH ZEROs
            if( i < BLOCK_SIZE )
                while( i < BLOCK_SIZE )
                    data.writeFloat( 0.0 );
                    ++i;
            //-- INCREASE SOUND POSITION
            _position += scaledBlockSize;
    kglad
    in complete() add a _mychannel soundcomplete listener that calls complete().
    Hi. Thank you very much for the reply. I have put what you told me. In complete I have put this:
                _myChannel = _sound.play(0, int.MAX_VALUE);
    			_myChannel.addEventListener( Event.SOUND_COMPLETE, complete );
    I put the complete code
    package
         * @7111211 Andre Michelle (andre.michelle@gmail.com)
        public class Bucle
    		private var _myChannel:SoundChannel;
                _mp3 = new Sound();
                _position = 0.0;
                _rate = 1.0;
                return _rate;
                if( value < 0.0 )
                    value = 0;
                _rate = value;
                //-- SHORTCUT
                var l0: Number;
                var r0: Number;
                var l1: Number;
                var r1: Number;
                    alpha += _rate;
                        ++i;
    and to call the class:
    Thanks for the attempt
    var pepe:Bucle = new Bucle ("ViolaGround.mp3");
    pepe.rate += 0.3;
    But, as before, it only sounds once.
    kglad
    check if complete is being called the first time.
    (and you have a lot of code errors possible because the forum is mangling your code.)
