Leo Miller989
Feb 7, 2026 3:49 PM UTC
Seeking Help: Proper JSFL Syntax for Setting 'Advanced' Color Mode Properties on Frames
I am trying to use JSFL to adjust an instance's Advanced Color Mode (Alpha).
My Action:
I manually select a keyframe on the timeline, then in the Frame Properties panel, under "Color Effect" -> "Advanced", I adjust the Alpha value there.
The Problem:
  1. I tried using getDocumentDOM().setInstanceAlpha(60), but this only adjusts the transparency in the "Object" tab, which is not what I want. I need to modify the Alpha property as seen in the "Frame" tab's Color Effect.
  2. I tried capturing the code from the History panel, but it generated getDocumentDOM().setElementProperty(%S, %S), which throws an "Argument is invalid" error when played back.
  3. I also tried getDocumentDOM().setElementProperty("alpha", 50), but it had no effect.
I have checked the official tutorials but couldn't find the correct property names for this specific panel.
My Question:
Could any experts tell me the correct JSFL syntax to adjust the Alpha transparency within the "Frame" (Color Effect) panel?
Mario_CR
Mario_CRCorrect answer
Feb 9, 2026 3:25 AM UTC
Try  layer.getColorTransformAtFrame()and layer.setColorTransformAtFrame()
Example from the documentation:
The following example copies the color transform of the first frame and sets it to the tenth frame:
var myCxform = an. getDocumentDOM(). getTimeline(). layers[0].getColorTransformAtFrame (0);
an.getDocumentDOM().getTimeline().layers[0]. setColorTransformAtFrame (9, myCxform);
https://github.com/AdobeDocs/developers-animatesdk-docs/blob/master/Layer_object/layer17.md
Mario_CR
Mario_CRCommunity ExpertCorrect answer
Leo Miller989
Feb 9, 2026 7:39 AM UTC
Thank you so much! I used the setColorTransformAtFrame() method you mentioned to successfully adjust the transparency in the frame panel—the result exceeded my expectations, and I'm thrilled!😄
I’ll later use a parameterized approach to fine-tune these values.
var tl = an.getDocumentDOM().getTimeline();
var customCxform = {
    colorAlphaPercent: 55,
    colorRedPercent: 100,
    colorGreenPercent: 100,
    colorBluePercent: 100,
    colorAlphaAmount: 0,
    colorRedAmount: 0,
    colorGreenAmount: 0,
    colorBlueAmount: 0
tl.layers[0].setColorTransformAtFrame(0, customCxform);
Mario_CR
Feb 9, 2026 6:14 PM UTC
You’re welcome, glad I could help.
