Using Action Script to detect single left-click, double left-click, and right click
  • June 1, 2017
  • 1555 views
I'm volunteering my time to teach individuals with disabilities to type and how to use office. However, when it came time to teach them office I found out that they do not know the basic keyboard commands, how to highlight text, or how to single left-click, double left-click, or right-click. I've used Flash before to create websites and other basic apps but I'm not good with Action Scripting and I know that what I want to teach will require a lot of Action Scripting. Could someone please help me figure this out? I would really appreciate it!!!
    Correct answer Joseph Labrecque
    There are a bunch of examples in the AS3 docs - I'd start there:
    MouseEvent - Adobe ActionScript® 3 (AS3 ) API Reference
    Colin Holgate
    Here is the help document for mouse events:
    You can see that you can listen for CLICK for left mouse click, RIGHT_CLICK for right mouse click, and for DOUBLE_CLICK.
    One catch is that to read doubleclicks you have to set the doubleClickEnabled = true;
    The bottom of the page includes example code.
    Thank you for the information for mouse click events but what about highlighting text and using keyboard commands such as Ctrl-C to copy and then CTRL-V for pasting?
    Adobe ActionScript 3.0 * Selecting and manipulating text
    I'm not sure what you're expecting regarding Ctrl-C and Ctrl-V. Those are physical, off-screen actions.
    Joseph Labrecque
    Joseph LabrecqueCommunity ExpertCorrect answer
