Mar 8, 2023 3:49 PM UTC
Why does Animate not work on MacBook Pro 2021 (M1 Pro chip)? Help please!
Why does Animate not work on MacBook Pro 2021 (M1 Pro chip)? Help please! Doesn't open old .fla files or even start up when opening from Creative Cloud.
    kglad
    Mar 8, 2023 4:42 PM UTC
    uninstall animate app including preferences per https://helpx.adobe.com/creative-cloud/help/uninstall-remove-app.html
    Joseph Labrecque
    Mar 8, 2023 4:32 PM UTC
    It must be some other issue as I'm running it on an M1 right now. Maybe try uninstall/reinstall or kill your preferences.
