Sony A7iv noise issue
- February 6, 2022
- 8 replies
- 25613 views
I bought a Sony A7iv in December and I have had constant issues editing photos in lightroom/camera raw. I am running the current version of camera raw (11.1 Camera Raw 14.1) and shooting uncompressed raw files in the camera. The issue I'm having is whenever I add clarity or boost the shadows or boost the exposure, I begin to get hundreds of white pixels in the shadows of the image to the point of being unpublishable.
I've made sure I'm not shooting in any picture profiles and DRO is off in the camera.
I've called both Sony and Adobe support. Sony had me open the raw files Imaging Edge - their proprietary software - and the issue didn't show up so they told me the won't help me. Adobe said can't do anything but the issue might get resolved whenever camera raw is updated. As a final test, I opened the images in Capture 1 and the white pixels aren't their but the image is so soft I wouldn't consider the image usable.
I've attached screen captures and a .jpg export of an example. You can see the adjustments I make to the image on the right side of the screen capture.
I've read online that some people had the same issue with the Sony A7iii and ended up returning is because the issue was never fixed. I'm a full-time photography that was planning on transition from Fuji to Sony but this is a serious issue that make this camera essentially a brick.
