geneh43302269
Need Longer to Set Pose For Body Tracker
  • June 7, 2021
  • 150 views
When I try to set the body tracker pose for the whole body, it only gives me five seconds to get far enough away from the camera to see my whole body.  I recently injured my ankle, so it grabs the pose before I can get into position.   I can only get far enough away for it to read my arms. I wish the user could set the countdown to their own speed.
Jeff Almasol
Adobe Employee
Adobe Employee
September 10, 2021
In the latest public Beta build of Character Animator, there's a new Timeline > Body Tracker Countdown submenu (with options for 5 sec, 10 sec, and 20 sec) that is used when you do a Calibrate (formerly called Set Rest Pose) or when you start a recording. Hope that helps.
