Coldfusion 10 changing cftoken and cfid on every call when load balanced
I seem to be having the issue described here
https://bugbase.adobe.com/index.cfm?event=bug&id=3572565
I have a Coldfusion 10 server.
It maintains sessions (via cookie) just fine UNTIL I load balance it with another CF 10 server.
When I do that, the cftoken and cfid cookies change on every hit to the web server.
Since the user login information is tied to the cftoken and cfid (stored in a database somewhere) the user will be logged out if these change.
The exact same production code works fine with two load balanced CF 8 servers.
my cfapplication looks like this:
<cfapplication name="Pappy"
sessionmanagement="Yes"
clientmanagement="Yes"
setDomainCookies = "Yes"
sessiontimeout="#CreateTimeSpan( 0, 8, 0, 0 )#"
if it matters client variables are stored in an sql server instance and are being stored just fine.
The bug is marked fixed in:
Bug#3593673 - Domain attribute of cfcookie is always trimmed to .domain.tld
I am on 10,0,13,287689 and this bug was fixed in 286333 according to the bug reference above.
TIA,
Don
