SSL problem when running Apache httpclient in Jrun and not in stand-alone Java
We are using the Apache httpclient 4.1.2 to post to an external server, using SSL. The post works fine when running it from the Java JRE , but when the code runs under a JRUN/Colfusion instance that uses the same Java JRE the error message returned is:
javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
      at com.sun.net.ssl.internal.ssl.SSLSessionImpl.getPeerCertificates(SSLSessionImpl.java:352)
      at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:128)
When debugging the connect using the -Djavax.net.debug=all setting, the error message shown internally is:
java.lang.RuntimeException: Could not generate secret
Is there some weird ColdFUsion setting we need to undo to make this work? We installed the cert from the other server in the /rje/lib/sercurity/cacerts file but that did not make a difference. Why does standalone java work and not Jrun?
The JDK version is 1.6.0_24-b07
Coldfusion: 9,0,1,274733
Joop KaashoekCorrect answer
OK, the solution was simple, to disable jsafe the proper way by adding the java command line property:
-Dcoldfusion.disablejsafe=true
Let's hope jsafe is not used for something vital...
Problem is solved. Doing a class loading analysis with the java option -verbose:class we we could see that in the ColdFusion case it was loading from the ../WEB-INF/lib/jsafeJCEFIPS.jar of the CF instance for key encryption and that was not the same as in the stand-alone case. So we got rid of that JAR and that made the SSL communication work properly..
Running a mix of J2EE and ColdFusion on the same instance has its challenges...
Problem is not solved, since the /WEB-INF/lib/jsafeJCEFIPS.jar file is needed for COldFusion servlets......
How to disable the RSA stuff for J2EE code running on the instance? Classpath sequence changes?
Joop KaashoekAuthorCorrect answer
