(CSS) Does 'display:none' still load associated images and just not display them, or do they not get loaded at all?
Let me be even more specific : Say I have half-a-dozen DIVs nested inside one another, and each has a different background image; then I will have 6 images to load... but what happens if the outer DIV - and only the outer div - is set to display:none?
All the child DIVs would still be there in the HTML - and their display is visible - but their container would have its display set to none... are those 6 images still being loaded in the background, in this context?
Or just the 5 inner ones?
(even though we can't see them and the bandwidth is wasted)
Or none?
(ie, if the container is set to display:none, then nothing inside gets processed, and nothing gets loaded)
Thanks!
PS: Could this behavior be different from browser to browser?
