Mar 16, 2021 6:29 PM UTC
Need help learning code [Was: Hello Help Help Help pleaseeee]
Hello, I am very new to Dreamweaver
I am wondering if anyone can help me with the basics of writing and editing codes.
[Edited by moderator for clarity.]
Jon Fritz
Mar 16, 2021 6:34 PM UTC
That's well beyond the scope of the forums, sorry.
DW assumes you have a decent unserstanding of the basics of html, css and javascript. Without those, it's going to be a very frustrating climb.
Fortunately, there are a lot of online resources that can have you coding in no time. Here's one I like for the basics, and the way they have the site laid out with the "Try It Yourself" links...
HTML: https://www.w3schools.com/html/
CSS: https://www.w3schools.com/css/
Javascript: https://www.w3schools.com/js/
Do the exercises, play with the code when presented with the option to do so, and you'll get a decent enough grip on the basics to start working with DW without going absolutely crazy.
Mar 16, 2021 6:37 PM UTC
Ok thanks
Somebody doing IGCSEs here????
Mar 16, 2021 6:38 PM UTC
So that I can get help easily??
