need this section to span edge to edge
I would like a section to span edge to edge, however, the content within can stay in the main content standard area. It is the background cover image in this section I'd like to see fill that space. Currently it comes to a halt and won't exceed stnd content area.
<div class="col-md-12 col-sm-12 col-xs-12">
<div id="content" class="content my-clearfix">
<div id="main">
<div class="the-modules-section"></div>
<div class="the-modules-section screenFull sectionBlock" style="background-image:url();background:url(http://#); background-repeat: no-repeat; background-position: center center; background-attachment: fixed; background-size: cover;"></div>
</div>
</div>
</div>
Not sure how I need to rearrange things, or if it really is just a matter of working with the styles to solve the problem?
Tried this - does not seem to have an affect.
.mainOptionBlocks {
  1.    margin: 0 auto;
  2.    max-width: 100% !important;
    BenPleysier
    Copy and paste the following code into a new document and view in browser.
    <!DOCTYPE html><html><head>
    <meta charset="UTF-8">
    <title>Untitled Document</title>
      <script type="text/javascript" src="https://code.jquery.com/jquery-3.3.1.slim.min.js" integrity="sha384-q8i/X+965DzO0rT7abK41JStQIAqVgRVzpbzo5smXKp4YfRvH+8abtTE1Pi6jizo" crossorigin="anonymous"></script>
      <meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">
      <link rel="stylesheet" type="text/css" href="https://stackpath.bootstrapcdn.com/bootstrap/4.1.0/css/bootstrap.min.css" integrity="sha384-9gVQ4dYFwwWSjIDZnLEWnxCjeSWFphJiwGPXr1jddIhOegiu1FwO5qRGvFXOdJZ4" crossorigin="anonymous">
      <link rel="stylesheet" type="text/css" href="https://maxcdn.bootstrapcdn.com/font-awesome/4.7.0/css/font-awesome.min.css" integrity="sha384-wvfXpqpZZVQGK6TAh5PVlGOfQNHSoD2xbE+QkPxCAFlNEevoEH3Sl0sibVcOQVnN" crossorigin="anonymous">
      </head>
      <body class="bg-warning">
        <section class="text-light bg-dark">
          <div class="container">
            <div class="row">
              <div class="col">
                <h1>My Heading</h1>
                <p>Some text</p>
              </div>
            </div>
          </div>
        </section>
        <script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/popper.js/1.14.0/umd/popper.min.js" integrity="sha384-cs/chFZiN24E4KMATLdqdvsezGxaGsi4hLGOzlXwp5UZB1LY//20VyM2taTB4QvJ" crossorigin="anonymous"></script>
        <script type="text/javascript" src="https://stackpath.bootstrapcdn.com/bootstrap/4.1.0/js/bootstrap.min.js" integrity="sha384-uefMccjFJAIv6A+rW+L4AHf99KvxDjWSu1z9VI8SKNVmz4sk7buKt/6v9KI65qnm" crossorigin="anonymous"></script>
      </body></html>
    Explanation:
    • the example uses the latest version of Bootstrap
    • Bootstrap grid follows the following hierarchy:
      • container (fixed/fluid)
      • row
      • column(s)
    • in the example, the container is wrapped in a section which, by default, stretches across the available width - in this case, the width of the body. A background colour ensures that the section is visible.
    The result:
    Wrapping anything in a section tag WITHOUT a heading tag following it wont validate correctly, you'll get a warning to consider using a heading tag. Personally I think that is completely stupid but I try and avoid using the section tag in those senarios. Wrapping the container in a <div> tag will probably work and you wont get the validator warning.
    At one point it was almost driving me nuts as I thought it was stupid but it appears you can have a heading in any child container.
    Join the club. Turning 75 next week and the crew think they are getting to go to a party.
    Congrates.......hope I'm well out of it and sitting by a river with a cold beer watching the world go around by time I reach 75.
    Sometimes I think hey this block of code would be good to wrap in a section tag, it might not necessarily warrant having a header tag and that's were it blows up. Not sure it is always necessary, or should always be necessary, to include a header tag within a section tag without getting a validation warning, but I don't make the rules up.
