TheKnightEagle
Jul 30, 2017 8:44 PM UTC
CNNgo blocks Adobe Flash - tried reinstall and setting, does not work unless I manually allow. Ideas on how to autocmatically allow flash?
[Moved from the non-technical Lounge Forum to a Flash forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
jeromiec83223024
Aug 9, 2017 11:35 PM UTC
The major U.S. browsers are making changes which make it more difficult to run Flash-based content.
While the browsers continue to be a moving target, we'll try to keep these documents up-to-date:
Enable Flash Player for Firefox
Enable Flash Player for Google Chrome
Adobe Flash Player enabled but not recognized in Windows 10 Edge
Enable Adobe Flash Player for Safari
ridhij4208356012135538
Adobe Employee
Adobe Employee
Jul 31, 2017 4:46 AM UTC
Please provide the following information:
  • OS you are using.
  • Browser you are using.
  • Version of Flash Player installed.
To check version of Flash Player installed you can go to Adobe - Flash Player page.
To get latest version of Flash Player go to Adobe Flash Player Install for all versions in your respective browser and download and install Flash Player.
Thanks!
TheKnightEagle
Jul 31, 2017 4:15 PM UTC
OS = Windows 10
Browser = Chrome
Flash = 26,0,0,137
