kacperr37645283
Aug 8, 2017 11:52 PM UTC
Flash player doesn't work on edge
Hi!
I can't enable my flash player on my browser. I'm use edge and chrome and situation is the same on the both. I was trying enable it on edge first with using help from Adobe support whatever without success. Finally I enabled flash player on edge but nothing was changed. To this moment i don't know how can i enable it and any instruction doesn't work. I downloaded the latest version of flash player. I'm working on laptop lenovo y50-70 with windows 10 home.
    ridhij4208356012135538
    Adobe Employee
    Adobe Employee
    Aug 9, 2017 5:52 AM UTC
    To enable Flash Player on Edge browser, refer to Troubleshooting Flash Player on Microsoft Edge and for Google Chrome refer to Use or fix Flash audio & video - Computer - Google Chrome Help .
    Thanks!
    kacperr37645283
    Aug 9, 2017 10:52 PM UTC
    I tried advanced enablement but i don't have folder Microsoft Edge. What can i do with this?
    kacperr37645283
    Aug 10, 2017 4:38 PM UTC
    Why my topic has been closed? I still have problem and u guys from Adobe just ignore your users. It's a kind of joke...
