Mar 26, 2016 1:54 AM UTC
Flash player will not work on windows 10. It is turned on in settings and advanced settings but it will not work.
This  is the result I keep getting when I follow the troubleshooting.
Flash Player is currently disabled.
Please follow the troubleshooting steps below to play Flash content.
    jeromiec83223024
    Apr 7, 2016 2:43 AM UTC
    To give you any useful advice, I'm going to need to know more about your computer and browser:
    https://forums.adobe.com/thread/1195540
    In the absence of details, I'm assuming we're talking about IE or Edge.
    First, confirm that ActiveX Filtering is configured to allow Flash content:
    https://forums.adobe.com/thread/867968
    Internet Explorer 11 and Edge introduce a number of changes both to how the browser identifies itself to remote web servers, and to how it processes JavaScript intended to target behaviors specific to Internet Explorer. Unfortunately, this means that content on some sites will be broken until the content provider changes their site to conform to the new development approach required by modern versions of IE.
    You can try to work around these issues by using Compatibility View:
    http://windows.microsoft.com/en-us/internet-explorer/use-compatibility-view#ie=ie-11
    If that is too inconvenient, using Google Chrome may be a preferable alternative.
