HELP! FLASH PLAYER WILL NOT FINISH INSTALLING! (OSX 10.6) - In DESPERATE need of help.
I've tried 100 times to install the latest flash player, but it stops at 95% every time and never goes any farther. I've tried uninstalling, restarting, re-downloading the Flash Player, and repairing my disk permissions and NOTHING works! Because I uninstalled it, I now have NO flash player at all! Kind of panicking. I need it for things I use to make a living.What do I do?
I have a Mac Pro 6 Core 6.33GB / 16GB of Ram
Sunil_Bhaskaran
Could you please download Flash Player from the following link: http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-mac.html#installer
Close all browsers and double-click the downloaded file.
Sunil
This continues to be a problem for years....most of the latest installs will not complete and stop at 95%. A force quit will terminate the installer BUT Flash WILL have been installed after all. But whatever it is supposed to happen after 95% never gets completed.This is after quitting all open apps, etc. So that is not the issue.
On some occasions, the installer for some versions have completed, but it has been a while since I have seen that happen. Currently on v19.0.0.226. On Mac OX X 10.6.8 on 27" 2010 iMac 2.93GHz i7.
