Help with Flash Player problems...
I did a Windows update a couple of days ago and it upgraded me to IE 10. Now I cannot view any videos on youtube or yahoo. I have all my drivers up to date and the latest flash player. I'm on Windows 7 64-bit. When I go to youtube, the video screen stays black and says "movie not loaded", but rarely it will play for 3-6 secs then restart, then stop at the 3-6 sec mark again. I have done all it says in the FAQ section in regards to having the add-ons enabled. I tried to just do a system restore to go back to normal, but for some reason there was only one restore point and it was after the update (which has caused nothing but headaches). Since the update I have had the above mentioned problems as well as I cannot get my Steam Client to connect at all, but thats another issue I'm sure. I've tried all I could think of as well as anything from the support sites. If anyone can offer any insite to this frustrating problem I would be very thankful. Otherwise I'm going to go all drastic and do a system reboot from disc, cause I only really use my computer for gaming and entertainment, both of which have been disabled from this last update. Also, I'm not sure whether this is relevant or not, but a lot of pages I've been visiting are all messed up with what looks like lines of code and web links all stacked up and all over the screen and I have to click the little broken page button on the address bar. All fun stuff. Thanks for any info I can get. I'll check back frequently to see any answers.
